snapmirror policy delete
- PDF of this doc site
Creating your file...
Your file is ready
Delete a SnapMirror policy
The snapmirror policy delete
command deletes a SnapMirror policy. A policy that is to be deleted must not be associated with any SnapMirror relationship. The built-in policies cannot be deleted.
-vserver <vserver name>
- Vserver Name-
Specifies the Vserver for the SnapMirror policy.
-policy <sm_policy>
- SnapMirror Policy Name-
Specifies the SnapMirror policy name.
The following example deletes a SnapMirror policy named TieredBackup
on Vserver vs0.example.com
vs0.example.com::> snapmirror policy delete -vserver vs0.example.com -policy TieredBackup
