ONTAP commands
storage aggregate efficiency cross-volume-dedupe start
Starts the cross volume background deduplication on an aggregate
The storage aggregate cross-volume-dedupe start command is used to start cross volume background deduplication on an aggregate.
-aggregate <aggregate name> - Aggregate
This specifies the aggregate on which cross volume background deduplication should be started. If no aggregate is specified then it will start on all aggregates
[-s, -scan-old-data <true>] - Scan Old Data
This option processes all the existing data on all volumes on the aggregate. It prompts for user confirmation before proceeding. Default value is false .
The following example displays information for starting cross volume background deduplication on aggregate "aggr1":
cluster:::> storage aggregate efficiency cross-volume-dedupe start -aggregate aggr1
The efficiency operation on aggregate "aggr1" has started.
cluster:::> storage aggregate efficiency cross-volume-dedupe start -aggregate aggr1 -scan-old-data true
