template provision
Provision Data ONTAP resources using the template
The command template provision
provisions ONTAP system based on the template that is passed as an input to the template parameter. A wizard is presented which will accept the required inputs.
-name <template name>
- Name of the template-
This parameter specifies the name of the template
[-simulate {true|false}]
- Simulate-
If this parameter is specified, the provisioning is just simulated and there will be no changes done to the system.
The following example provisions a vserver with required protocols using template.
cluster-1::> template provision -name VserverEnvironmentSetup Press Ctrl+C to abort. ******************** * Setup of vserver * ******************** Vserver Name: vs0 Vserver Language [C.UTF-8]: Vserver Security Style [unix]: Vserver IPSpace [Default]: ****************************** * Setup of network.interface * ****************************** Enter number of instances for object network.interface: 2 (1/2)LIF Protocol: nfs (1/2)IP Addr: 1.1.1.1 (1/2)NetMask: 255.255.255.0 (1/2)Node Name: node1-vsim1 (1/2)Port: e0c (2/2)LIF Protocol: nfs (2/2)IP Addr: 1.1.1.1 (2/2)NetMask: 255.255.255.0 (2/2)Node Name: node1-vsim1 (2/2)Port: e0c *************************** * Setup of network.routes * *************************** Enter number of instances for object network.routes: 1 (1/1)Gateway: 1.1.1.1 *********************** * Setup of access.dns * *********************** Search Domain: netapp.com DNS IP Addresses List: 1.1.1.1 ************************* * Setup of security.nis * ************************* NIS Domains: netapp.com NIS IP Address: 1.1.1.1 ********************* * Setup of security * ********************* LDAP Client Config: ldapconfig LDAP Server IP: 1.1.1.1 LDAP Base DN: dc=examplebasedn ********************** * Setup of protocols * ********************** Protocols to configure: nfs [Job 15] Configuring vserver for vs0 (100%)
