storage path show
PDF of this doc site
Creating your file...
Display a list of paths to attached arrays.
The storage path show
command displays path based statistics. The default command shows:
Node name
Initiator port
Target port
Target IQN
TPGN
Port speeds
Path I/O in Kbytes/sec
IOPs
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-array ]
Using this option displays:
Array name
Target port
Target IQN
Target I/O in Kbytes/sec
Target side switch port
Initiator side switch port
Initiator I/O in Kbytes/sec
Initiator port
[-by-target ]
Using this option displays the same information as the array option, but grouped by target port.
