ONTAP commands
system license delete
Delete a license
This command deletes a license from a cluster.
-serial-number <text> - Serial Number
This parameter specifies the serial number of the license that is to be deleted from the cluster. If this parameter is not provided, the default value is the serial number of the cluster.
-package <Licensable Package> - Package
This parameter specifies the name of the package that is to be deleted from the cluster.
The following example deletes a license named CIFS and serial number 1-81-0000000000000000000123456 from the cluster:
cluster1::> system license delete -serial-number 1-81-0000000000000000000123456 -package CIFS
Looking for answers?
Try Doc, our Gen AI Assistant.
