vserver services access-check authentication login-cifs
Authenticate a CIFS user
The vserver services access-check authentication login-cifs command authenticates a Windows user through the specified node using the specified Vserver’s configuration. Upon success, it displays the user’s Windows and UNIX credentials.
[-node {<nodename>|local}] - Node
The name of the node on which the command is executed.
-vserver <vserver> - Vserver
The name of a Vserver with a configured CIFS server.
-user <text> - Windows Name
The name of a user that is a member of the Windows or a trusted domain that the CIFS server in the specified Vserver belongs to.
[-clientIp <IP Address>] - Client IP Address
The IP address of the client as specified by the user
This example authenticates the Windows user "administrator" through node "node2" using the configuration of "vs1." Upon success, it displays the Windows and UNIX credentials for user "administrator."
cluster1::vserver services access-check*> authentication login-cifs -vserver vs1 -user administrator -node node2
Enter the password:
Windows User: administrator Domain: EXAMPLE Privs: a7
 Primary Grp: S-1-5-21-1407423728-2963865486-1834115207-513
      Domain: S-1-5-21-1407423728-2963865486-1834115207 Rids: 500, 520, 513, 22226, 26625, 1842, 512, 519, 518, 8323, 1645, 1648, 1644, 1647
      Domain: S-1-1 Rids: 0
      Domain: S-1-5 Rids: 11, 2
     Unix ID: 0, GID: 0
       Flags: 1
   Domain ID: 0
  Other GIDs:
Authentication Succeeded.
