security login domain-tunnel modify
Modify authentication tunnel Vserver for administrative Vserver
The security login domain-tunnel modify command modifies or replaces the tunnel Vserver. If a tunnel Vserver is not already specified, it sets the current tunnel Vserver with this Vserver, otherwise, it replaces the current tunnel Vserver with the Vserver that you specify. If the tunnel Vserver is changed, authentication requests via previous Vserver will fail. See security login domain-tunnel create for more information.
[-vserver <vserver>] - Authentication Tunnel Vserver
This parameter specifies a Vserver that has been configured with CIFS and is associated with a Windows Domain Controller's Active Directory authentication. This Vserver will be used as an authentication tunnel for login accounts so that they can be used with administrative Vservers.
The following command modifies the tunnel Vserver for administrative Vserver.
cluster1::> security login domain-tunnel modify -vserver vs
