ONTAP commands
job resume
Resume a job
The job resume command resumes a job that was previously paused by using the job pause command. Use the job show command to view a list of paused jobs that can be resumed.
-id <integer> - Job ID
The numeric ID of the paused job to be resumed. A job ID is a positive integer.
[-vserver <vserver name>] - Owning Vserver
Use this parameter to specify the name of the Vserver that owns the job.
The following example resumes the paused job that has ID 183:
cluster1::> job resume -id 183
