      system smtape abort
Abort an active SMTape session
This command aborts the backup or restore operations based on the session identifier. You can perform SMTape operations using the system smtape backup or system smtape restore commands. A unique session identifier is assigned for each new SMTape operation. This command aborts sessions that are in active and waiting states.
- -session <Sequence Number>- Session Identifier
Use this parameter to specify the session identifier for a backup or restore session.
Abort the SMTape session with the session identifier 20
cluster1::> system smtape abort -session 20 Abort posted to session 20.
 PDFs
PDFs
