volume show-footprint
Display a list of volumes and their data and metadata footprints in their associated aggregate.
The volume show-footprint command displays information about the space used in associated aggregates by volumes and features enabled in volumes. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all volumes. + + If the associated aggregates have an object-store attached to them, then the command displays a more detailed split up of the space used in each tier. This additional information is useful to show per-tier space usage which can be used to estimate the space requirements and transfer duration when moving a volume to a different tier with volume move .
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter and the
-volumeparameter are specified, the command displays detailed information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver. [-volume <volume name>]- Volume Name-
-vserverparameter are specified, the command displays detailed information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name. [-volume-msid <integer>]- Volume MSID-
If this parameter is specified, the command displays information only about the volume that has the specified MSID.
[-volume-dsid <integer>]- Volume DSID-
If this parameter is specified, the command displays information only about the volume that has the specified DSID.
[-vserver-uuid <UUID>]- Vserver UUID-
If this parameter is specified, the command displays information only about the volume on the vserver which has the specified UUID.
[-aggregate <aggregate name>]- Aggregate Name-
If this parameter is specified, the command displays information only about the volumes that are associated with the specified aggregate.
[-aggregate-uuid <UUID>]- Aggregate UUID-
If this parameter is specified, the command displays information only about the volumes on the aggregate which have the specified UUID.
[-hostname <text>]- Hostname-
If this parameter is specified, the command displays information only about the volumes that belong to the specified host.
[-tape-backup-metafiles-footprint {<integer>[KB|MB|GB|TB|PB]}]- Tape Backup Metadata Footprint-
If this parameter is specified, the command displays information only about the volumes whose tape backup metafiles use the specified amount of space in the aggregate.
[-tape-backup-metafiles-footprint-percent <percent>]- Tape Backup Metadata Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose tape backup metafiles use the specified percentage of space in the aggregate.
[-dedupe-metafiles-footprint {<integer>[KB|MB|GB|TB|PB]}]- Deduplication Footprint-
If this parameter is specified, the command displays information only about the volumes whose deduplication metafiles use the specified amount of space in the aggregate.
[-dedupe-metafiles-footprint-percent <percent>]- Deduplication Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose deduplication metafiles use the specified percentage of space in the aggregate.
[-dedupe-metafiles-temporary-footprint {<integer>[KB|MB|GB|TB|PB]}]- Temporary Deduplication Footprint-
If this parameter is specified, the command displays information only about the volumes whose temporary deduplication metafiles use the specified amount of space in the aggregate.
[-dedupe-metafiles-temporary-footprint-percent <percent>]- Temporary Deduplication Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose temporary deduplication metafiles use the specified percentage of space in the aggregate.
[-cross-volume-dedupe-metafiles-footprint {<integer>[KB|MB|GB|TB|PB]}]- Cross Volume Deduplication Footprint-
If this parameter is specified, the command displays information only about the volumes whose cross volume deduplication metafiles use the specified amount of space in the aggregate.
[-cross-volume-dedupe-metafiles-footprint-percent <percent>]- Cross Volume Deduplication Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose cross volume deduplication metafiles use the specified percentage of space in the aggregate.
[-cross-volume-dedupe-metafiles-temporary-footprint {<integer>[KB|MB|GB|TB|PB]}]- Cross Volume Temporary Deduplication Footprint-
If this parameter is specified, the command displays information only about the volumes whose cross volume deduplication temporary metafiles use the specified amount of space in the aggregate.
[-cross-volume-dedupe-metafiles-temporary-footprint-percent <percent>]- Cross Volume Temporary Deduplication Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose cross volume deduplication temporary metafiles use the specified percentage of space in the aggregate.
[-volume-blocks-footprint {<integer>[KB|MB|GB|TB|PB]}]- Volume Data Footprint-
If this parameter is specified, the command displays information only about the volumes whose data blocks use the specified amount of space in the aggregate.
This field is the total amount of data written to the volume. It includes data in the active file system in the volume as well as data that is consumed by volume Snapshot copies. This row only includes data and not reserved space, so when volumes have reserved files, the volume's total used in the volume show-space command output can exceed the value in this row.
[-volume-blocks-footprint-percent <percent>]- Volume Data Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose data blocks use the specified percentage of space in the aggregate.
[-flexvol-metadata-footprint {<integer>[KB|MB|GB|TB|PB]}]- Flexible Volume Metadata Footprint-
If this parameter is specified, the command displays information only about the volumes whose file system metadata uses the specified amount of space in the aggregate.
This field includes the space used or reserved in the aggregate for metadata associated with this volume.
[-flexvol-metadata-footprint-percent <percent>]- Flexible Volume Metadata Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose file system metadata uses the specified percentage of space in the aggregate.
[-delayed-free-footprint {<integer>[KB|MB|GB|TB|PB]}]- Delayed Free Blocks-
If this parameter is specified, the command displays information only about the volumes whose delayed free blocks use the specified amount of space in the aggregate.
When Data ONTAP frees space in a volume, this space is not always immediately shown as free in the aggregate. This is because the operations to free the space in the aggregate are batched for increased performance. Blocks that are declared free in the FlexVol volume but which are not yet free in the aggregate are called "delayed free blocks" until the associated delayed free blocks are processed. For SnapMirror destinations, this row will have a value of 0 and will not be displayed.
[-delayed-free-footprint-percent <percent>]- Delayed Free Blocks Percent-
If this parameter is specified, the command displays information only about the volumes that have the specified amount of blocks waiting to be freed in the aggregate. This space is called "delayed free blocks".
[-snapmirror-destination-footprint {<integer>[KB|MB|GB|TB|PB]}]- SnapMirror Destination Footprint-
If this parameter is specified, the command displays information only about the volumes whose SnapMirror transfer uses the specified amount of space in the aggregate.
During a SnapMirror transfer, this row will include incoming SnapMirror data and SnapMirror-triggered delayed free blocks from previous SnapMirror transfers.
[-snapmirror-destination-footprint-percent <percent>]- SnapMirror Destination Footprint Percent-
If this parameter is specified, the command displays information only about the volumes whose SnapMirror transfer uses the specified percentage of space in the aggregate.
[-volume-guarantee-footprint {<integer>[KB|MB|GB|TB|PB]}]- Volume Guarantee-
If this parameter is specified, the command displays information only about the volumes whose guarantees use the specified amount of space in the aggregate.
This field includes the amount of space reserved by this volume in the aggregate for future writes. The amount of space reserved depends on the guarantee type (the provisioning mode) of the volume. + For a "volume" guaranteed volume, this is the size of the volume minus the amount in the Volume Data Footprint row. + For a "file" guaranteed volume, this is the sum of all of the space reserved for hole fills and overwrites in all of the space reserved files in the volume.
[-volume-guarantee-footprint-percent <percent>]- Volume Guarantee Percent-
If this parameter is specified, the command displays information only about the volumes whose guarantees use the specified percentage of space in the aggregate.
[-file-operation-metadata {<integer>[KB|MB|GB|TB|PB]}]- File Operation Metadata-
If this parameter is specified, the command displays information only about the volumes that have file operation metadata using the specified amount of space in the aggregate.
This metadata is used by file move and copy operations. Although it is not returned as free space once the operations are complete, it can be reused by future file operations.
[-file-operation-metadata-percent <percent>]- File Operation Metadata Percent-
If this parameter is specified, the command displays information only about the volumes that have file operation metadata using the specified percentage of space in the aggregate.
[-total-footprint {<integer>[KB|MB|GB|TB|PB]}]- Total Footprint-
If this parameter is specified, the command displays information only about the volumes which use the specified amount of space in the aggregate. This field is the sum of the other rows in this table.
[-total-footprint-percent <percent>]- Total Footprint Percent-
If this parameter is specified, the command displays information only about the volumes which use the specified percentage of space in the aggregate.
[-aggregate-size {<integer>[KB|MB|GB|TB|PB]}]- Containing Aggregate Size-
If this parameter is specified, the command displays information only about the volumes that are associated with an aggregate of the specified size.
[-bin0-name <text>]- Name for bin0-
If this parameter is specified, the command displays information only about volumes whose associated aggregate has an object store attached to it with an active file system tier name matches the specified value.
[-volume-blocks-footprint-bin0 {<integer>[KB|MB|GB|TB|PB]}]- Volume Footprint for bin0-
If this parameter is specified, the command displays information only about volumes whose space in use in the performance tier of the aggregate matches the specified value.
[-volume-blocks-footprint-bin0-percent <percent>]- Volume Footprint bin0 Percent-
If this parameter is specified, the command displays information only about volumes whose percentage space in use in the performance tier of the aggregate matches the specified value.
[-bin1-name <text>]- Name for bin1-
If this parameter is specified, the command displays information only about volumes whose associated aggregate has an external capacity tier attached to it with a configuration name that matches the specified value.
[-volume-blocks-footprint-bin1 {<integer>[KB|MB|GB|TB|PB]}]- Volume Footprint for bin1-
If this parameter is specified, the command displays information only about volumes whose space in use in the first external capacity tier bucket attached to the associated aggregate matches the specified value. This includes the space used by the blocks in the volume that are staged before being moved to the capacity tier.
[-volume-blocks-footprint-bin1-percent <percent>]- Volume Footprint bin1 Percent-
If this parameter is specified, the command displays information only about volumes whose percentage space in use in the first external capacity tier bucket attached to associated aggregate matches the specified value. This includes the space used by the blocks in the volume that are staged before being moved to the capacity tier.
The following example displays information about all volumes in the system.
cluster1::> volume show-footprint
Vserver : nodevs
Volume : vol0
Feature Used Used%
Volume Data Footprint 103.1MB 11%
Volume Guarantee 743.6MB 83%
Flexible Volume Metadata 4.84MB 1%
Delayed Frees 4.82MB 1%
Total Footprint 856.3MB 95%
Vserver : thevs
Volume : therootvol
Feature Used Used%
Volume Data Footprint 116KB 0%
Volume Guarantee 19.83MB 1%
Flexible Volume Metadata 208KB 0%
Delayed Frees 60KB 0%
Total Footprint 20.20MB 1%
Vserver : thevs
Volume : thevol
Feature Used Used%
Volume Data Footprint 128KB 0%
Volume Guarantee 2.00GB 76%
Flexible Volume Metadata 11.38MB 0%
Delayed Frees 428KB 0%
Total Footprint 2.01GB 76%
3 entries were displayed.
The following example displays information about all volumes in a system and highlights a scenario where the aggregates associated with volumes have an external capacity tier attached to them.
cluster-1::> vol show-footprint
Vserver : vsim1
Volume : vol0
Feature Used Used%
Volume Data Footprint 2.57GB 81%
Volume Guarantee 266.1MB 8%
Flexible Volume Metadata 16.23MB 0%
Delayed Frees 27.97MB 1%
Total Footprint 2.87GB 90%
Vserver : vs1
Volume : svm_root
Feature Used Used%
Volume Data Footprint 2.93MB 0%
Footprint in Performance Tier 2.99MB 100%
Footprint in my-store 0B 0%
Volume Guarantee 17.01MB 0%
Delayed Frees 68KB 0%
Total Footprint 20.20MB 0%
Vserver : vs1
Volume : vol1
Feature Used Used%
Volume Data Footprint 1.61GB 17%
Footprint in Performance Tier 1.23GB 72%
Footprint in my-store 479.0MB 28%
Volume Guarantee 0B 0%
Flexible Volume Metadata 16.06MB 0%
Delayed Frees 82.98MB 1%
Total Footprint 1.71GB 18%
Vserver : vs1
Volume : vol2
Feature Used Used%
Volume Data Footprint 1.22GB 13%
Footprint in Performance Tier 823.3MB 65%
Footprint in ms1 440MB 35%
Delayed Frees 12MB 0%
Total Footprint 1.25GB 13%
4 entries were displayed.
