vserver peer transition create
Create a new transition peer relationship between a 7-Mode system and a Vserver.
The vserver peer transition create command creates a transition peer relationship between a 7-Mode system and a Vserver.
-local-vserver <vserver name> - Local Vserver name
Specifies the name of the local Vserver.
-src-filer-name <text> - Source 7-Mode system
Specifies the name of the source 7-Mode system (hostname or IP address).
[-multi-path-address <text>] - Additional address for source 7-Mode system
Additional address (hostname or IP address) for the source 7-Mode system.
[-local-lifs <lif-name>,…​] - List of Local LIFs
List of LIFs to be used for this peering relationship. The LIF role can be data or node-mgmt or intercluster or cluster-mgmt.
The following example illustrates how to create a transition peer relationship between Vserver vs1.example.com , residing on Cluster1 , and a 7-Mode system src1.example.com . We can also specify an additional multipath address src1-e0d.example.com , for load balancing and list of local LIFs lif1, lif2 to be used.
Cluster1::> vserver peer transition create -vserver vs1.example.com -src-filer-name src1.example.com -multi-path-address src1-e0d.example.com
-local-lifs lif1,lif2
