ONTAP commands
system license capacity show
(DEPRECATED)-Show license capacity status
Note This command is deprecated and may be removed in a future release of Data ONTAP. Use the "system license show-status " command.
The system license capacity show command displays the information about the licenses in the system that are specifically related to storage capacity limits.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-serial-number <Node Serial Number>] - Serial Number
If you use this parameter, the command displays information only about the capacity-related licenses that matches the serial number you specify.
[-package <Licensable Package>] - Package
If you use this parameter, the command displays information only about the package you specify.
[-owner <text>] - Owner
If you use this parameter, the command displays information only about the capacity-related licenses that have the owner you specify.
[-max-capacity {<integer>[KB|MB|GB|TB|PB]}] - Maximum Capacity
If you use this parameter, the command displays information only about the capacity-related licenses that have the maximum amount of attached storage capacity you specify.
[-current-capacity {<integer>[KB|MB|GB|TB|PB]}] - Current Capacity
If you use this parameter, the command displays information only about the capacity-related licenses that apply to the node with the current attached capacity you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>] - Expiration Date
If you use this parameter, the command displays information only about the capacity-related licenses that have the expiration date you specify.
[-reported-state {evaluation|warning|missing|enforcement|installed}] - Reported State
If you use this parameter, the command displays information only about the capacity-related licenses that have the reported state you specify.
[-node {<nodename>|local}] - Node Name
If you use this parameter, the command displays information only about the capacity-related licenses that apply to the node you specify.
The following example displays information about all capacity-related licensed packages in the cluster, for a hypothetical cluster of four nodes:
Note that for some nodes below, the maximum capacity is displayed as "-" (meaning "unlimited"). This happens when there is no capacity license for the node - the node is operating with a limited-time temporary capacity license.
cluster1::> system license capacity show
Node:          node1
Serial Number: 1-81-0000000000001234567890123456
                              Max  Current
Package                  Capacity Capacity Expiration
Select                        2TB  15.81GB 4/11/2016 00:00:00
Node:          node2
Serial Number: 1-81-0000000000000000000123456788
                              Max  Current
Select                          -  10.40TB 4/11/2016 00:00:00
Node:          node3
Serial Number: 1-81-0000000000000000000123456789
                              Max  Current
Node:          node4
                              Max  Current
