system services manager install show
- PDF of this doc site
Creating your file...
Display a list of installed services
The system services manager install show
command displays information about installed services.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-service <text>]
- Service-
Selects information about installed services that have the name you specify.
[-version <service version>]
- Version-
Selects information about installed services that have the version number you specify.
[-constituent <text>]
- Constituent-
Selects information about installed services that have the constituent process you specify.
[-nodes {<nodename>|local}]
- Nodes-
Selects information about services that are installed on the nodes you specify.
[-description <text>]
- Description-
Selects information about installed services that match the description you specify.
The following example shows typical output from a two-node cluster.
cluster1::> system services manager install show Service Version Constituent Nodes ----------------- ------- ----------- --------------------------------------- diagnosis 1.0 schmd node1, node2 1.0 shmd node1, node2 2 entries were displayed.
