network interface service-policy rename
Rename an existing network service policy
The network interface service-policy rename command assigns a new name to an existing service policy without disrupting the LIFs using the policy.
-vserver <vserver name>- Vserver (privilege: advanced)-
Use this parameter to specify the name of the Vserver of the service policy to be renamed.
-policy <text>- Policy Name (privilege: advanced)-
Use this parameter to specify the name of the service policy to be renamed.
-new-name <text>- New Service Policy Name (privilege: advanced)-
Use this parameter to specify the new name for the service policy.
The following example shows the renaming of a service policy.
cluster1::> network interface service-policy show
Vserver Policy Service: Allowed Addresses
cluster1
empty -
net-intercluster intercluster-core: 0.0.0.0/0
2 entries were displayed.
cluster1::> network interface service-policy rename -vserver cluster1 -policy empty -new-name still-empty
cluster1
still-empty -
