system controller sp upgrade show
Display the Service Processor Upgrade Table
The system controller sp upgrade show command displays the following information about the service processor firmware of all the nodes in the cluster:
Node name
Is new firmware available?
Is autoupdate enabled?
Status of autoupdate
Health monitor status
To display more details, use the -instance parameter. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed upgrade information of the service processor.
[-node {<nodename>|local}]- Node-
Use this parameter to list the upgrade information of the service processor on the specified node.
[-new-fw-avail {true|false}]- New Firmware Available-
Selects the information of the service processors which have new firmware available.
[-new-fw-version <text>]- New Firmware Version-
Selects the information about service processors with the specified firmware version.
[-auto-update {true|false}]- Auto Update-
Selects the information about service processors with the specified state.
[-auto-update-stat {installed|corrupt|updating|auto-updating|none}]- Auto Update Status-
Selects the information about service processors with the specified auto update status.
[-auto-update-sttime <MM/DD/YYYY HH:MM:SS>]- Auto Update Start Time-
Selects the information about service processors with the specified start time.
[-auto-update-entime <MM/DD/YYYY HH:MM:SS>]- Auto Update End Time-
Selects the information about service processors with the specified end time.
[-auto-update-per <integer>]- Auto Update Percent Done-
Selects the information about service processors with the specified auto update percentage completed.
[-auto-update-maxret <integer>]- Auto Update Maximum Retries-
Selects the information about service processors with the specified maximum number of retries.
[-auto-update-curret <integer>]- Auto Update Current Retries-
Selects the information about service processors with the specified number of current retries.
[-auto-update-prevstat {failed|passed}]- Previous AutoUpdate Status-
Selects the information about service processors with the specified automatic update status.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example}]- Health Monitor Name-
Selects the information about service processors with the specified monitor name.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Status-
Selects the information about service processors with the specified health monitor status.
[-name <text>]- Display Name-
Selects the information about service processors with the specified display name.
The example below displays service processor upgrade information for all nodes in the cluster:
cluster1::> system controller sp upgrade show New Firmware Auto Update Auto Update Node Available Feature Status Status ---- --------------- ------------ -------------- --------- node1 false true installed ok node2 false true installed ok 2 entries were displayed.
The example below displays the detailed service processor upgrade information for a specific node:
cluster1::> system controller sp upgrade show -instance -node node1
Node: node1
New Firmware Available: false
New Firmware Version: Not Applicable
Auto Update: true
Auto Update Status: installed
Auto Update Start Time: Thu Oct 20 20:06:03 2012 Etc/UTC
Auto Update End Time: Thu Oct 20 20:09:19 2012 Etc/UTC
Auto Update Percent Done: 0
Auto Update Maximum Retries: 5
Auto Update Current Retries: 0
Previous AutoUpdate Status: passed
Health Monitor Name: controller
Status: ok
Display Name: SP Upgrade
