network interface service-policy create
Create a new service policy
The network interface service-policy create command creates a new service policy with a list of included services. LIFs can reference this policy to control the list of services that they are able to transport on their network. Services can represent applications accessed by a LIF as well as applications served by this cluster.
-vserver <vserver name>- Vserver-
Use this parameter to specify the name of the Vserver on which the service policy will be created.
-policy <text>- Policy Name-
Use this parameter to specify the name of service policy to be created.
[-services <LIF Service Name>,…]- Included Services-
Use this parameter to specify a list of services that should be included in this policy.
[-allowed-addresses <IP Address/Mask>,…]- Allowed Addresses-
Use this parameter to specify a list of subnet masks for addresses that are allowed to access the services in this policy. Use the value
0.0.0.0/0to represent the wildcard IPv4 address and::/0to represent the wildcard IPv6 address.
The following example shows the creation of a service policy with no initial services.
cluster1::> network interface service-policy create -vserver cluster1 -policy empty
cluster1::> network interface service-policy show
Vserver Policy Service: Allowed Addresses
cluster1
empty -
net-intercluster intercluster-core: 0.0.0.0/0
2 entries were displayed.
The following example shows the creation of a new service policy with a specified service list.
cluster1::> network interface service-policy create -vserver cluster1 -policy metrocluster -services repl-mcc-nvlog,repl-mcc-storage
cluster1
empty -
metrocluster repl-mcc-nvlog: 0.0.0.0/0
repl-mcc-storage: 0.0.0.0/0
3 entries were displayed.
