storage bridge modify
Modify a bridge's configuration information
The storage bridge modify enables you to modify certain parameters for identifying and accessing the FC-to-SAS bridges added for monitoring in a MetroCluster configuration.
-name <text>- Bridge Name-
This parameter specifies the name of the bridge.
[-address <IP Address>]- Bridge IP Address-
This parameter specifies the IP address of the bridge.
[-snmp-community <text>]- SNMP Community Set on the Bridge-
This parameter specifies the SNMP community set on the bridge.
[-managed-by {SNMP|in-band}]- Bridge Management Method-
This parameter specifies whether the bridge uses the SNMP or in-band management method. FibreBridge 6500N uses SNMP only; FibreBridge7500 may use either.
[-node-visible-list <text>,…]- Nodes Bridge is Visble To-
List of nodes with FC visibility to the bridge.
The following command modifies 'ATTO_10.226.197.16' bridge SNMP community to 'public':
cluster1::> storage bridge modify -name ATTO_10.226.197.16 -address 10.226.197.16 -snmp-community public cluster1::>
