security protocol modify
Modify application configuration options
The security protocol modify
command modifies the existing cluster-wide configuration of RSH and Telnet. Enable RSH and Telnet in the cluster by setting the enabled field as true
-application <text>
- application-
Selects the application. Supported values are
rsh
andtelnet
. [-enabled {true|false}]
- enabled-
Enables or disables the corresponding application. The default value is
false
The following command enables RSH in the cluster. The default setting for RSH is false
cluster1::> security protocol modify -application rsh -enabled true
The following command enables Telnet in the cluster. The default setting for Telnet is false
cluster1::> security protocol modify -application telnet -enabled true
