security protocol modify
Modify application configuration options
The security protocol modify command modifies the existing cluster-wide configuration of RSH and Telnet. Enable RSH and Telnet in the cluster by setting the enabled field as true .
-application <text> - application
Selects the application. Supported values are rsh and telnet .
[-enabled {true|false}] - enabled
Enables or disables the corresponding application. The default value is false .
The following command enables RSH in the cluster. The default setting for RSH is false :
cluster1::> security protocol modify -application rsh -enabled true
The following command enables Telnet in the cluster. The default setting for Telnet is false :
cluster1::> security protocol modify -application telnet -enabled true
