vserver nfs prepare-for-hadoop-non-root-mount-downgrade
Remove -hadoop-allow-non-root-mount field on all Vservers
The vserver nfs prepare-for-hadoop-non-root-mount-downgrade command removes -hadoop-allow-non-root-mount field on all the Vservers and disables the hadoop.non_root.mount capability on the cluster when downgrading Data ONTAP to a version that does not support Hadoop Non-Root Mount feature.
The following example removes -hadoop-allow-non-root-mount field on the Vservers and disables the hadoop.non_root.mount capability.
cluster::1> vserver nfs prepare-for-hadoop-non-root-mount-downgrade
