network tcpdump show
PDF of this doc site
Creating your file...
Show running tcpdump instances
The network tcpdump show
command shows currently running packet traces (via tcpdump) on a matching node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
Use this parameter optionally to show the details of running packet traces on a matching node.
[-port {<netport>|<ifgrp>}]
- Port-
Use this parameter optionally to show the details of running packet trace on a matching network interface.
The following example shows the details of running packet traces on nodes "node1" and "node2":
cluster1::> network tcpdump show Node Port ---------- -------- node1 e0a node2 e0c
