system controller replace resume
- PDF of this doc site
Creating your file...
Your file is ready
Resume paused controller replacement
The system controller replace resume
command is used to resume an update that is currently in one of paused-on-request, paused-on-error or paused-for-intervention states. If the update is not paused then an error is returned.
The following example shows a resume operation:
cluster1::> system controller replace resume Controller replacement resumed successfully.
