      network bgp peer-group modify
Modify a BGP peer group
The network bgp peer-group modify command is used to modify a border gateway protocol (BGP) peer group configuration.
- -ipspace <IPspace>- IPspace Name
This parameter specifies the IPspace of the peer group being modified.
- -peer-group <text>- Peer Group Name
This parameter specifies the name of the peer group being modified.
- [-peer-address <IP Address>]- Peer Router Address
This parameter specifies an updated value for the IP address of the peer router.
cluster1::> network bgp peer-group modify -ipspace Default -peer-group peer1 -peer-address 10.10.10.10
 PDFs
PDFs
