ONTAP commands
volume encryption conversion show
Show status of a volume encryption conversion
The volume encryption conversion show command displays information about volume encryption conversion in the cluster. By default, with no parameters, it only shows volume encryption operations that have failed or are currently running. The command display output depends on the parameters passed. If -vserver and -volume are specified, the following information is displayed:
  • Vserver Name: The Vserver on which the volume is located.
  • Volume Name: The volume that is part of a completed or running volume move operation.
  • Start Time: The date and time when the volume encryption operation was started.
  • Status of Operation: The status of the operation.
  • Percentage Completed: The amount of work to encrypt the volume completed thus far in terms of percentage.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>] - Volume Name
This parameter specifies the name of the volume being encrypted.
[-start-time <MM/DD/YYYY HH:MM:SS>] - Start Time
If this parameter is specified, the command displays encryption operations that match the specified date and time in the cluster time zone when the volume move operation started.
[-status <text>] - Status
If this parameter is specified, the command displays encryption operations that match the specified status of the encryption operation.
The following example shows a sample output for this command:
cluster1::> volume encryption conversion show
Vserver    Volume       Start Time            Status
vs1        p2           9/18/2017 17:44:36    Phase 2 of 2 is in
                                              progress.
