ONTAP 9.5 commands
storage tape alias set
Set an alias name for tape drive or media changer
This command sets an alias name for a tape drive or media changer.
-node {<nodename>|local} - Node
Use this parameter to specify the node to which the tape drive is attached.
-name <text> - Alias Name for Tape Drive or Media Changer
Use this parameter to specify the alias name for tape drive or media changer. For a tape drive alias name, the format is 'st' followed by one or more digits. For a media changer alias name, the format is 'mc' followed by one or more digits.
-mapping <text> - Mapping for Alias Name
Use this parameter to specify the mapping for an alias name. Use the format 'SN[<serial-number> ]'. Valid mapping for serial numbers are in the format 'SN[<serial-number> ]' where the <serial-number> is from 2 to 90 characters long and includes the following characters: 0-9, a-z, and A-Z.
The following example sets an alias name 'st3' for a tape drive with serial number SN[123456]L4 attached to the node, node1.
cluster1::storage tape alias> set  -node node1 -name st3 -mapping SN[123456]L4.
The following example sets an alias name 'mc1' for a media changer with serial number SN[65432] attached to the node, node1.
cluster1::storage tape alias> set  -node node1 -name mc1 -mapping SN[65432].
