vserver vscan enable
Enable Vscan on a Vserver
The vserver vscan enable command enables Vscan on a Vserver.
-vserver <vserver name>- Vserver-
This parameter specifies the name of the Vserver on which you want to enable Vscan. The Vscan configuration must already exist.
The following example enables Vscan on Vserver vs1.
cluster1::> vserver vscan enable -vserver vs1 cluster1::> vserver vscan show -vserver vs1 Vserver: vs1 Vscan Status: on
