security login motd modify
Modify the message of the day
The security login motd modify command updates the message of the day (MOTD).
There are two categories of MOTDs: the cluster-level MOTD and the data Vserver-level MOTD. A user logging in to a data Vserver's clustershell will potentially see two messages: the cluster-level MOTD followed by the Vserver-level MOTD for that Vserver. The cluster administrator can enable or disable the cluster-level MOTD on a per-Vserver basis. If the cluster administrator disables the cluster-level MOTD for a Vserver, a user logging into the Vserver will not see the cluster-level message. Only a cluster administrator can enable or disable the cluster-level message.
-vserver <Vserver Name> - Vserver Name
Use this parameter to specify the Vserver whose MOTD will be modified. Use the name of the cluster admin Vserver to modify the cluster-level message.
{ [-message <text>] - Message of the Day (MOTD)
This optional parameter can be used to specify a message. If you use this parameter, the MOTD cannot contain newlines (also known as end of lines (EOLs) or line breaks). If you do not specify any parameter other than the -vserver parameter, you will be prompted to enter the message interactively. Messages entered interactively can contain newlines. Non-ASCII characters must be provided as Unicode UTF-8.
The message may contain dynamically generated content using the following escape sequences:
  • \\ - A single backlash character.
  • \b - No output: supported for compatibility with Linux only.
  • \C - Cluster name.
  • \d - Current date as set on the login node.
  • \t - Current time as set on the login node.
  • \I - Incoming LIF IP address (prints 'console' for a console login).
  • \l - Login device name (prints 'console' for a console login).
  • \L - Last login for the user on any node in the cluster.
  • \m - Machine architecture.
  • \n - Node or data Vserver name.
  • \N - Name of user logging in.
  • \o - Same as \O. Provided for Linux compatibility.
  • \O - DNS domain name of the node. Note that the output is dependent on the network configuration and may be empty.
  • \r - Software release number.
  • \s - Operating system name.
  • \u - Number of active clustershell sessions on the local node. For the cluster admin: all clustershell users. For the data Vserver admin: only active sessions for that data Vserver.
  • \U - Same as \u, but has 'user' or 'users' appended.
  • \v - Effective cluster version string.
  • \W - Active sessions across the cluster for the user logging in ('who').
A backslash followed by any other character is emitted as entered.
| [-uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…​}] - Download URI for the MOTD }
Use this parameter to specify the URI from where the message of the day will be downloaded. Note that the message must not exceed 2048 bytes in length. Non-ASCII characters must be provided as Unicode UTF-8.
[-is-cluster-message-enabled {true|false}] - Is Cluster-level Message Enabled?
Use this parameter to enable or disable the display of the cluster-level MOTD for the specified Vserver.
This example shows how to enter a MOTD interactively:
cluster1::> security login motd modify -vserver vs0
Enter the message of the day for Vserver "vs0".
Max size: 2048. Enter a blank line to terminate input. Press Ctrl-C to abort.
0        1         2         3         4         5         6         7         8
12345678901234567890123456789012345678901234567890123456789012345678901234567890
Welcome to the Vserver!
cluster1::>
