vserver vscan on-demand-task show
Display On-Demand tasks
The vserver vscan on-demand-task show command displays information about the On-Demand tasks belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all On-Demand tasks:
Vserver name
Task name
Scan paths
Report directory path
Schedule
You can specify the -fields parameter to specify which fields of information to display about On-Demand tasks. In addition to the fields above, you can display the following fields:
Max file size
File paths to exclude
File extensions to exclude
File extensions to include
Scan files without extension
Scan timeout
Cross junction
Directory recursion
Scan priority
Report log level
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the On-Demand tasks for the specified Vserver.
[-task-name <text>]- Task Name-
If you specify this parameter, the command displays information only about the specified On-Demand task.
[-scan-paths <text>,…]- List of Scan Paths-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the scan-paths list.
[-report-directory <text>]- Report Directory Path-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-directory.
[-schedule <text>]- Job Schedule-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified schedule.
[-max-file-size {<integer>[KB|MB|GB|TB|PB]}]- Max File Size Allowed for Scanning-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified max-file-size.
[-paths-to-exclude <text>,…]- File Paths Not to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the exclude list.
[-file-ext-to-exclude <File extension>,…]- File Extensions Not to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the exclude list.
[-file-ext-to-include <File extension>,…]- File Extensions to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the include list.
[-scan-files-with-no-ext {true|false}]- Scan Files with No Extension-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified value.
[-request-timeout <[<integer>h][<integer>m][<integer>s]>]- Request Service Timeout-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified request-timeout.
[-cross-junction {true|false}]- Cross Junction-
[-directory-recursion {true|false}]- Directory Recursion-
[-scan-priority {low|normal}]- Scan Priority-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified scan-priority.
[-report-log-level {verbose|info|error}]- Report Log Level-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-log-level.
The following example displays information about all On-Demand tasks:
cluster1::> vserver vscan on-demand-task show
Report
Vserver Task Name Scan Paths Directory Path Schedule
vs1 t1 /test /report -
vs2 t2 /, /test/ /report daily
2 entries were displayed.
The following example displays detailed information about an On-Demand task:
cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1
Vserver: vs1
Task Name: t1
List of Scan Paths: /test
Report Directory Path: /report
Job Schedule: -
Max File Size Allowed for Scanning: 2GB
File Paths Not to Scan: /vol1/cold-files/
File Extensions Not to Scan: mp3, mp4
File Extensions to Scan: *
Scan Files with No Extension: true
Request Service Timeout: 1m
Cross Junction: true
Directory Recursion: true
Scan Priority: low
Report Log Level: verbose
