event notification delete
Delete event notifications
The event notification delete
command deletes an existing event notification.
-ID <integer>
- Event Notification ID-
Use this parameter to specify the ID of the notification to be deleted.
The following example shows the deletion of event notification with ID 1:
cluster1::> event notification show ID Filter Name Destinations ----- ---------------- ----------------- 1 filter1 email_dest, syslog_dest, snmp-traphost cluster1::> event notification delete -ID 1 cluster1::> event notification show This table is currently empty.
