      volume encryption conversion pause
Pause a running volume encryption conversion operation
The volume encryption conversion pause command pauses the running encryption conversion operation on a volume.
- -vserver <vserver name>- Vserver Name
This parameter specifies the Vserver on which the volume is located.
- -volume <volume name>- Volume Name
This parameter specifies the name of the volume being encrypted.
- [-ignore-warning {true|false}]- Ignore Warning for Conversion Pause
If this parameter is set, the command ignores the confirmation message.
 PDFs
PDFs
