system services manager policy show
Display service policies
The system services manager policy show
command displays information about policies that determine which versions of a service can run on the nodes of the cluster.
Use the system services manager status show command to view information about services that are configured to run in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-service <text>]
- Service-
Selects policies that apply to the service you specify.
[-version <service version>]
- Version-
Selects policies that have the version number you specify.
[-constituent <text>]
- Constituent-
Selects policies that have the constituent process you specify.
[-state {on|off}]
- State-
Use this parameter with the value "on" to select information about policies that are currently active. Use this parameter with the value "off" to select information about policies that are not currently active.
[-num-active <integer>]
- Number Active-
Selects policies that have the number of active (running) instances you specify.
[-target-nodes <service affinity>,…]
- Target Nodes-
Selects policies that are configured to run on the nodes you specify.
[-tag <UUID>]
- Tag-
Selects policies that have the UUID you specify. Use this parameter with the
-fields
parameter to display a list of the UUIDs of configured services.
The following example shows typical output for this command.
cluster1::> system services manager policy show Service Version State Constituent Number Target Active Nodes ----------------- ------- ----- ----------- ------ -------------------------- diagnosis 1.0 on schmd 1 any 1.0 on shmd 1 any 2 entries were displayed.
