volume flexcache sync-properties
Sync FlexCache volume properties with its origin
The volume flexcache sync-properties command is used to sync a FlexCache volumes properties with its origin volume.
This command only needs to be used when there was a failure to sync properties from the origin of a FlexCache volume to the FlexCache volume. |
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the FlexCache volume is located.
-volume <volume name>- FlexCache Volume Name (privilege: advanced)-
This specifies the FlexCache volume whose properties need to be synced with its origin of a FlexCache volume.
cluster1::> flexcache sync-properties -volume fc1 -vserver vs34
(volume flexcache sync-properties)
