The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume flexcache sync-properties
PDF of this doc site
Creating your file...
Your file is ready
Sync volume properties
The volume flexcache sync-properties
command is used to sync a FlexCache volume's properties with its origin volume or to update FlexCache origin volume name in FlexCache relationship during a origin volume rename operation in disconnected mode.
This command should be used when there is a failure to sync properties from the origin of a FlexCache volume to the FlexCache volume or to update the FlexCache origin volume name in the FlexCache relationship in the case of a volume rename from the origin in disconnected mode. |
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
Specifies the SVM on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced)-
Specifies the volume name whose properties need to be synced. If the volume is a FlexCache volume, its properties are synced with its origin volume. If the volume is a FlexCache origin volume, the origin volume name is updated in the FlexCache relationship where the origin volume is renamed in disconnected mode.
cluster1::> flexcache sync-properties -volume fc1 -vserver vs34 (volume flexcache sync-properties)
