volume flexcache sync-properties
Sync volume properties
The volume flexcache sync-properties
command is used to sync a FlexCache volume's properties with its origin volume or to update FlexCache origin volume name in FlexCache relationship during a origin volume rename operation in disconnected mode.
This command should be used when there is a failure to sync properties from the origin of a FlexCache volume to the FlexCache volume or to update the FlexCache origin volume name in the FlexCache relationship in the case of a volume rename from the origin in disconnected mode. |
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
Specifies the SVM on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced)-
Specifies the volume name whose properties need to be synced. If the volume is a FlexCache volume, its properties are synced with its origin volume. If the volume is a FlexCache origin volume, the origin volume name is updated in the FlexCache relationship where the origin volume is renamed in disconnected mode.
cluster1::> flexcache sync-properties -volume fc1 -vserver vs34 (volume flexcache sync-properties)
