system license show-aggregates
Display status of aggregates leases and license used.
This command displays the status of all ONTAP aggregates.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If you use this parameter, the command displays information only about aggregates that match the given node.
[-aggr-name <text>]- Aggregate Name-
If you use this parameter, the command displays information only about aggregate that match the given aggregate.
[-aggr-size {<integer>[KB|MB|GB|TB|PB]}]- Aggregate Size-
If you use this parameter, the command displays information only about aggregates that match the given physical size of an aggregate.
[-licensed-size {<integer>[KB|MB|GB|TB|PB]}]- Licensed Size-
If you use this parameter, the command displays information only about aggregates that match the given licensed-size.
[-expiration <MM/DD/YYYY HH:MM:SS>]- Lease Expiration-
If you use this parameter, the command displays information only about aggregates that match the given lease expiration.
[-status <AggrLicStatus>]- Aggregate Status-
If you use this parameter, the command displays information only about aggregates that match the given status.
[-compliant {true|false}]- Is Aggregate Compliant-
If you use this parameter, the command displays information only about aggregates that match the given state of compliance.
The following example displays the license status of the cluster:
cluster1::> system license show-aggregates
Licensed Physical
Node Aggregate Size Size Lease Expiration Status
node1
root1 0B 2GB - lease-not-required
root2 (mirror) 0B 2GB - lease-not-required
aggr1 20GB 20GB 6/21/2018 18:10:00 lease-up-to-date
aggr2 (mirror) 10GB 10GB 6/21/2018 20:00:00 lease-up-to-date
node2
root1 (mirror) 0B 2GB - lease-not-required
root2 0B 2GB - lease-not-required
aggr1 (mirror) 20GB 20GB 6/21/2018 18:10:00 lease-up-to-date
aggr2 10GB 10GB 6/21/2018 20:00:00 lease-up-to-date
node3
root3 0B 2GB - lease-not-required
root4 (mirror) 0B 2GB - lease-not-required
aggr3 15GB 0B 6/21/2018 20:00:00 aggregate-deleted
aggr4 (mirror) 15GB 15GB 6/21/2018 12:00:00 lease-expired
aggr5 (mirror) 15GB 15GB 6/21/2018 21:00:00 lease-up-to-date
aggr6 15GB 15GB 6/21/2018 21:00:00 plex-deleted
aggr7 15GB 14GB 6/21/2018 21:00:00 aggregate-license-size-decreased
aggr8 (mirror) 0B 14GB - lease-missing
node4
root3 (mirror) 0B 2GB - lease-not-required
root4 0B 2GB - lease-not-required
aggr3 (mirror) 15GB 0B 6/21/2018 20:00:00 aggregate-deleted
aggr4 15GB 15GB 6/21/2018 12:00:00 lease-expired
aggr5 15GB 15GB 6/21/2018 21:00:00 lease-up-to-date
aggr6 (mirror) 15GB 0B 6/21/2018 21:00:00 plex-deleted
aggr7 (mirror) 15GB 14GB 6/21/2018 21:00:00 aggregate-license-size-decreased
aggr8 0B 14GB - lease-missing
