metrocluster configuration-settings interface create
Create a MetroCluster interface
The metrocluster configuration-settings interface create command configures the network logical interfaces that will be used on a node in a MetroCluster setup to mirror NV logs and access remote storage.
This command is used for MetroCluster setups that are connected though IP links. MetroCluster setups that are connected through FC links do not require the user to provision network logical interfaces to mirror NV logs and access remote storage.
The metrocluster configuration-settings commands are run in the following order to set up MetroCluster:
metrocluster configuration-settings interface create,
Before running this command , the node's DR group must be configured using the metrocluster configuration-settings dr-group create command. Run the metrocluster configuration-settings dr-group show command to verify that the node's DR group has been configured.
-cluster-name <Cluster name>- Cluster Name-
Use this parameter to specify the name of the local or partner cluster.
 -home-node <text>- Home Node-
Use this parameter to specify the home node in the cluster which hosts the interface.
 -home-port {<netport>|<ifgrp>}- Home Port-
Use this parameter to specify the home port provisioned for MetroCluster.
 -address <IP Address>- Network Address-
Use this parameter to specify the network address to be assigned to the home port.
 -netmask <Contiguous IP Mask>- Netmask-
Use this parameter to specify the network mask to be assigned to the interface.
This example shows configuring logical interface on MetroCluster IP capable port:
clusA::>  metrocluster configuration-settings interface create -cluster-name clusA -home-node A1 -home-port e0f -address 10.140.113.214 -netmask 255.255.192.0
[Job 281] Job succeeded: Interface Create is successful.
clusA::> metrocluster configuration-settings interface show
DR        Config
Group Cluster Node    Network Address Netmask         Gateway         State
1     clusA A1
                 Home Port: e0f
                                       10.140.113.214  255.255.192.0   -               completed
Output after configuring all the interfaces:
DR        Config
1     clusA A1
                 Home Port: e0f
                 Home Port: e0g
                      10.140.113.215  255.255.192.0   -               completed
                       A2
                 Home Port: e0f
                      10.140.113.216  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.217  255.255.192.0   -               completed
      clusB B2
                 Home Port: e0f
                      10.140.113.249  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.25   255.255.192.0   -               completed
                       B1
                 Home Port: e0f
                      10.140.113.218  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.248  255.255.192.0   -               completed
8 entries were displayed.
clusA::> metrocluster configuration-settings show-status
Cluster                    Node               Configuration Settings Status
clusA
                           A1                 ready for connection connect
                           A2                 ready for connection connect
clusB
                           B1                 ready for connection connect
                           B2                 ready for connection connect
4 entries were displayed.
clusA::> metrocluster configuration-settings connection show
DR                    Source          Destination
Group Cluster Node    Network Address Network Address Partner Type Config State
1     clusA A1
                 Home Port: e0f
                      10.140.113.214  10.140.113.216  HA Partner   disconnected
                 Home Port: e0f
                      10.140.113.214  10.140.113.218  DR Partner   disconnected
                 Home Port: e0f
                      10.140.113.214  10.140.113.249  DR Auxiliary disconnected
                 Home Port: e0g
                      10.140.113.215  10.140.113.217  HA Partner   disconnected
                 Home Port: e0g
                      10.140.113.215  10.140.113.248  DR Partner   disconnected
                 Home Port: e0g
                      10.140.113.215  10.140.113.25   DR Auxiliary disconnected
                       A2
                 Home Port: e0f
                      10.140.113.216  10.140.113.214  HA Partner   disconnected
                 Home Port: e0f
                      10.140.113.216  10.140.113.249  DR Partner   disconnected
                 Home Port: e0f
                      10.140.113.216  10.140.113.218  DR Auxiliary disconnected
                 Home Port: e0g
                      10.140.113.217  10.140.113.215  HA Partner   disconnected
                 Home Port: e0g
                      10.140.113.217  10.140.113.25   DR Partner   disconnected
                 Home Port: e0g
                      10.140.113.217  10.140.113.248  DR Auxiliary disconnected
      clusB B2
                 Home Port: e0f
                      10.140.113.249  10.140.113.218  HA Partner   disconnected
                 Home Port: e0f
                      10.140.113.249  10.140.113.216  DR Partner   disconnected
                 Home Port: e0f
                      10.140.113.249  10.140.113.214  DR Auxiliary disconnected
                 Home Port: e0g
                      10.140.113.25   10.140.113.248  HA Partner   disconnected
                 Home Port: e0g
                      10.140.113.25   10.140.113.217  DR Partner   disconnected
                 Home Port: e0g
                      10.140.113.25   10.140.113.215  DR Auxiliary disconnected
                       B1
                 Home Port: e0f
                      10.140.113.218  10.140.113.249  HA Partner   disconnected
                 Home Port: e0f
                      10.140.113.218  10.140.113.214  DR Partner   disconnected
                 Home Port: e0f
                      10.140.113.218  10.140.113.216  DR Auxiliary disconnected
                 Home Port: e0g
                      10.140.113.248  10.140.113.25   HA Partner   disconnected
                 Home Port: e0g
                      10.140.113.248  10.140.113.215  DR Partner   disconnected
                 Home Port: e0g
                      10.140.113.248  10.140.113.217  DR Auxiliary disconnected
24 entries were displayed.
