vserver migrate start
Start the Vserver migrate operation
This command starts the migration of a Vserver from one cluster to another. This has to be run on the destination cluster, i.e. the cluster where the Vserver is intended to migrate. The source cluster from where the Vserver is to be migrated is specified in the command.
- -vserver <vserver name>- Vserver Name (privilege: advanced)
Name of the Vserver which needs to be migrated.
- -source-cluster <Cluster name>- Source Cluster Name (privilege: advanced)
Name of the source cluster.
- [-check-only {true|false}]- Check if migrate can be done (privilege: advanced)
Runs the prechecks and tells if the Vserver migrate operation can be started or not.
- [-ipspace <IPspace>]- Destination cluster IPspace Name for vserver (privilege: advanced)
Name of the IPspace in the destination cluster.
- [-aggr-list <aggregate name>,…]- Aggregate list (privilege: advanced)
Provide the list of aggregates where the volumes will be created in the destination cluster.
- [-force {true|false}]- Force flag for continuing with disruptive migrate (privilege: advanced)
The force parameter is set to true when the user wants Vserver migrate operation to continue to completion even though the 30 sec cutover duration is not met. When this parameter is used, it indicates that the admin wants to perform a disruptive migrate operation.
- [-auto-cutover {true|false}]- Automatically cutover when ready (privilege: advanced)
This parameter is to specify if the Vserver migrate operation should cutover automatically when ready.
- [-skip-performance-check {true|false}]- Skip checking iops requirement of volume on destination aggregates (privilege: advanced)
This parameter is set to true when the user wants the Vserver migrate operation to skip checking IOPS requirement of volume on destination aggregates.
cluster1::> vserver migrate start -vserver test -source-cluster cluster-22 -ipspace ips1 -check-only true -aggr-list aggr1,aggr2 -force false -auto-cutover false -skip-performance-check false
 PDFs
PDFs
