snapmirror snapshot-owner show
Display Snapshot Copies with Owners
The snapmirror snapshot-owner show command is used to list all Snapshot copies with owners that were added using the snapmirror snapshot-owner create command.
[-fields <fieldname>,…] -
If this parameter is specified, the command displays information about the specified fields.
[-instance ]} -
If this parameter is specified, the command displays detailed information about all fields.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume.
[-snapshot <snapshot name>]- Snapshot Copy Name-
If this parameter is specified, the command displays the owner name for the specified Snapshot copy.
The following example lists all Snapshot copies with owners on volume vol1 in Vserver vs0 . The system-generated default owner name is displayed as "-".
cluster1::> snapmirror snapshot-owner show
-vserver vs0.example.com -volume vol1
Vserver Volume Snapshot Owner Names
vs0.example.com
vol1 snap2 -
snap1 app1
The following example displays the owner name for Snapshot copy snap1 on volume vol1 in Vserver vs0.example.com .
-vserver vs0.example.com -volume vol1 -snapshot snap1
Vserver: vs0.example.com
Volume: vol1
Snapshot: snap1
Owner Names: app1
