job history show
Display a history of jobs
The job history show command displays a history of completed jobs with newer entries displayed first. You can specify optional parameters to select information about job history items that match only those parameters. For example, to display information about jobs that were completed on February 27 at noon, run the command with -endtime "02/27 12:00:00" .
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the completed jobs that match this parameter value.
[-record <Sequence Number>] - Record ID
Selects the completed jobs that match the record ID or range of record IDs you specify. Note that record IDs are unique for each node, not for the cluster as a whole. As a result, there can be two records with the same record ID within the cluster.
[-vserver <vserver name>] - Owning Vserver
Selects the completed jobs that are owned by the Vserver you specify.
[-id <integer>] - Job ID
[-endtime <MM/DD HH:MM:SS>] - End Time
Selects jobs that completed at the time you specify. This parameter is most useful when used with a range of times.
[-starttime <MM/DD HH:MM:SS>] - Start Time
Selects completed jobs that were started at the time you specify. This parameter is most useful when used with a range of times.
[-name <text>] - Name
[-description <text>] - Description
[-code <integer>] - Status Code
Selects the completed jobs that match this parameter value. Each job defines its own status codes. The completion text is more informative, but s
