volume encryption rekey pause
Pause a running volume encryption rekey operation
The volume encryption rekey pause
command pauses the running encryption rekey operation on a volume.
-vserver <vserver name>
- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This parameter specifies the name of the volume being encrypted.
[-ignore-warning {true|false}]
- Ignore Warning for Rekey Pause-
If this parameter is set, the command ignores the confirmation message.
