system cluster-switch log setup-password
Obtain cluster switch admin passwords
The system cluster-switch log setup-password command allows the user to enable the cluster switch health monitor to setup access to certain cluster switches so that the switch logs can be collected.
cluster1::> system cluster-switch log setup-password
Enter the switch name: (use full name from system cluster-switch show)
Enter the password: (Enter admin password of switch)
Enter the password again: (Enter admin password of switch)
cluster1::>
Enables setup of switch logging for the specified cluster switch.
