The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system cluster-switch log setup-password
PDF of this doc site
Creating your file...
Your file is ready
Obtain cluster switch admin passwords
The system cluster-switch log setup-password
command allows the user to enable the cluster switch health monitor to setup access to certain cluster switches so that the switch logs can be collected.
cluster1::> system cluster-switch log setup-password Enter the switch name: (use full name from system cluster-switch show) Enter the password: (Enter admin password of switch) Enter the password again: (Enter admin password of switch) cluster1::>
Enables setup of switch logging for the specified cluster switch.
