volume efficiency policy modify
Modify an efficiency policy
The volume efficiency policy modify
command can be used to modify the policy attributes.
The attributes of the inline-only
predefined policy cannot be modified.
-vserver <vserver name>
- Vserver-
This specifies the Vserver on which the volume is located.
-policy <text>
- Efficiency Policy Name-
This specifies the policy name.
[-type <Efficiency policy type>]
- Policy Type-
This specifies the policy type. The policy type defines when the volume using this policy will start processing a changelog. There are two possible values:
threshold
means changelog processing occurs when the changelog reaches a certain percentage. -
scheduled
means changelog processing will be triggered by time.
The default value is
scheduled
[-schedule <text>]
- Job Schedule Name-
This specifies the job schedule. Use job schedule show to show all the jobs.
[-duration <text>]
- Duration-
This specifies the duration that an efficiency operation can run in hours. The possible value is between 1 and 999 inclusive.
[-start-threshold-percent <percent>]
- Threshold Percentage-
The percentage at which the changelog will be processed. The percentage is checked on an hourly basis. The default value is 20. Valid only if
-type
parameter is set asthreshold
. [-qos-policy <Efficiency QoS policy>]
- QoS Policy-
This specifies how the efficiency operations are throttled. This option can be configured to be
background
orbest-effort
. Default value isbest-effort
. Ifbackground
is specified, the efficiency operations are run with minimum or no impact on the data serving client operations. Ifbest-effort
is specified, the efficiency operations might have some impact on the data serving client operations. [-enabled {true|false}]
- Enabled-
This specifies whether the policy is enabled or not. Default value is true.
[-comment <text>]
- Comment-
User specified comment.
The following example modifies efficiency policy.
cluster1::> volume efficiency policy modify -policy policy1 -schedule hourly
