vserver peer transition delete
Delete a transition peer relationship.
The vserver peer transition delete
command deletes the transition peer relationship.
-local-vserver <vserver name>
- Local Vserver name-
Specifies the name of the local Vserver.
-src-filer-name <text>
- Source 7-Mode system-
Specifies the name of the source 7-Mode system(hostname or IP address).
The following example illustrates how to delete the transition peer relationship between a Vserver lvs1.example.com
residing on cluster1
, and source 7-Mode systemsrc1.example.com
cluster1::> vserver peer transition delete -vserver lvs1.example.com -src-filer-name src1.example.com
