vserver nvme namespace delete
Delete the namespace
The vserver nvme namespace delete command deletes an NVMe namespace from a specified Vserver and volume.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
-path <path>- Namespace Path-
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths are
/vol/vol1/ns1and/vol/vol1/qtree1/ns1. [-skip-mapped-check <true>]- Skip Mapped Check-
This option is required to delete an NVMe namespace that is attached to a subsystem.
cluster1::*> vserver nvme namespace delete -vserver vs1 -path /vol/nsvol/ns1
Deletes the NVMe namespace at path /vol/nsvol/ns1 on Vserver vs1 .
