job show-cluster
PDF of this doc site
Creating your file...
Display a list of cluster jobs
The job show-cluster
command displays information about cluster-affiliated jobs. The command output depends on the parameters specified with the command. If no parameters are specified, the command displays information about all cluster-affiliated jobs.
To display detailed information about a specific job, run the command with the -id
parameter. The detailed view includes all of the default information plus additional items.
You can specify additional parameters to display only information that matches the values you specify for those parameters. For example, to display information only about jobs running on a specific node, run the command with the -node
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-id <integer>]
- Job ID-
Use this parameter to display information only about the jobs that match the ID or range of IDs you specify.
[-vserver <vserver name>]
- Owning Vserver-
Use this parameter with the name of a Vserver to display only jobs that are owned by that Vserver.
[-name <text>]
- Name-
Use this parameter to display information only about the jobs that match the job name you specify.
[-description <text>]
- Description-
Use this parameter to display information only about the jobs that match the description you specify.
[-priority {Low|Medium|High|Exclusive}]
- Priority-
Use this parameter to display information only about the jobs that match the priority you specify.
[-node <nodename>]
- Node-
Use this parameter to display information only about the jobs that are associated with the node you specify.
[-affinity {Cluster|Node}]
- Affinity-
Use this parameter with an affinity value to display only jobs that match the affinity you specify.
[-schedule <job_schedule>]
- Schedule-
Use this parameter to display information only about the jobs that run on the schedule you specify.
[-queuetime <MM/DD HH:MM:SS>]
- Queue Time-
Use this parameter to display information only about the jobs that match the queue time you specify.
