ONTAP 9.3 commands
job show-cluster
Display a list of cluster jobs
The job show-cluster command displays information about cluster-affiliated jobs. The command output depends on the parameters specified with the command. If no parameters are specified, the command displays information about all cluster-affiliated jobs.
To display detailed information about a specific job, run the command with the -id parameter. The detailed view includes all of the default information plus additional items.
You can specify additional parameters to display only information that matches the values you specify for those parameters. For example, to display information only about jobs running on a specific node, run the command with the -node parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-id <integer>] - Job ID
Use this parameter to display information only about the jobs that match the ID or range of IDs you specify.
[-vserver <vserver name>] - Owning Vserver
Use this parameter with the name of a Vserver to display only jobs that are owned by that Vserver.
[-name <text>] - Name
Use this parameter to display information only about the jobs that match the job name you specify.
[-description <text>] - Description
Use this parameter to display information only about the jobs that match the description you specify.
[-priority {Low|Medium|High|Exclusive}] - Priority
Use this parameter to display information only about the jobs that match the priority you specify.
[-node <nodename>] - Node
Use this parameter to display information only about the jobs that are associated with the node you specify.
[-affinity {Cluster|Node}] - Affinity
Use this parameter with an affinity value to display only jobs that match the affinity you specify.
[-schedule <job_schedule>] - Schedule
Use this parameter to display information only about the jobs that run on the schedule you specify.
[-queuetime <MM/DD HH:MM:SS>] - Queue Time
Use this parameter to display information only about the jobs that match the queue time you specify.
[-starttime <MM/DD HH:MM:SS>] - Start Time
Use this parameter to display information only about the jobs that match the start time you specify.
[-endtime <MM/DD HH:MM:SS>] - End Time
Use this parameter to display information only about the jobs that match the end time you specify.
[-dropdeadtime <MM/DD HH:MM:SS>] - Drop-dead Time
Use this parameter to display information only about the jobs that match the final timeout time you specify.
[-restarted {true|false}] - Restarted?
Use this parameter to display information only about the jobs that match the restart value you specify.
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - State
Use this parameter to display information only about the jobs that match the job state you specify.
[-code <integer>] - Status Code
Use this parameter to display information only about the jobs that match the status code you specify.
[-completion <text>] - Completion String
Use this parameter to display information only about the jobs that match the completion text you specify.
[-jobtype <text>] - Job Type
Use this parameter to display information only about the jobs that match the job type you specify.
[-category <text>] - Job Category
Use this parameter to display information only about the jobs that match the job category you specify.
[-uuid <UUID>] - UUID
Use this parameter to display information only about the jobs that match the UUID you specify.
[-username <text>] - User Name
Use this parameter with a username to display only jobs that are associated with the user you specify.
The following example displays information about all cluster-affiliated jobs:
cluster1::> job show-cluster
                        Owning
Job ID Name             Vserver   Node           State
305    Auto_Mirror      node-vserver
                                  -              Running
6202   mirror-03_10     node-vserver
                                  -              Queued
       Descr:Auto mirror
6203   mirror-04_10     node-vserver
                                  -              Queued
       Descr:Auto mirror
6204   mirror-01_10     node-vserver
                                  -              Queued
       Descr:Auto mirror
6205   mirror-02_10     node-vserver
                                  -              Queued
       Descr:Auto mirror
6206   mirror-05_10     node-vserver
                                  -              Queued
       Descr:Auto mirror
