system controller flash-cache secure-erase run
Perform a secure-erase operation on the targeted devices
The system controller flash-cache secure-erase run command securely erases the givien Flash Cache device.
-node {<nodename>|local}- Node-
Selects the node of the specified Flash Cache devices.
-slot <text>- Slot-
Selects the slot or slot-subslot of the specified Flash Cache devices.
The following example securely erases the selected Flash Cache device:
cluster1::> system controller flash-cache secure-erase -node node1 -slot 0-1
