vserver security trace trace-result delete
Delete security trace results
Delete the specified security tracing event record.
-node {<nodename>|local} - Node
This parameter specifies the cluster node on which the permission tracing event that you want to delete occurred.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver on which the permission tracing event that you want to delete occurred.
-seqnum <integer> - Sequence Number
This parameter specifies the sequence number of the log entry to be deleted.
The following example deletes the security trace result record for the Vserver ``_vserver_1_`` on node ``_Node_1_`` whose sequence number is ``_999_`` .
cluster1::> vserver security trace trace-result delete -vserver vserver_1 -node Node_1 -seqnum 999
