network route create
Create a static route
The network route create command creates a static route within a Vserver.
- -vserver <vserver>- Vserver Name
Use this parameter to specify the Vserver on which the route is to be created.
- -destination <IP Address/Mask>- Destination/Mask
Use this parameter to specify the IP address and subnet mask of the route's destination. The format for this value is: address, slash ("/"), mask. 0.0.0.0/0is a valid destination value to create default IPv4 route. And::/0is a valid destination value to create default IPv6 route
- -gateway <IP Address>- Gateway
Use this parameter to specify the IP address of the gateway server leading to the route's destination.
- [-metric <integer>]- Metric
Use this parameter to specify the metric of the route.
The following example creates default routes within Vserver vs0 for IPv4 and IPv6.
cluster1::> network route create -vserver vs0 -destination 0.0.0.0/0 -gateway 10.61.208.1 cluster1::> network route create -vserver vs0 -destination ::/0 -gateway 3ffe:1::1
 PDFs
PDFs
